CBS channel not working on plex
#1
I have been watching several shows on plex for a long time and since yesterday CBS no longer works or has hickups. I recently upgraded to PMS 1.10.1.4602 on Windows 10. My Windows 7 version has the same issue. Other channels work. I followed the guidelines on how to get a channel to work and what to check for. Regional setting is set for US. I reside in the US and am not using a VPN.
The channel listings are available but playing content I simply get an empty screen and it just seems to be spinning without retrieving any content, there is no progress indicator, none so it is also not a transcoder issue. Can somebody pls assist?
#2
Pls see attached debug file. There is no error notification there.
#3
I’m also on PMS 1.10.1.4602 (but on Mac). CBS works fine from here.
Other log files that might show errors are com.plexapp.system.log (for errors in the URL Service code) or Plex Media Server.log (for transcode errors).
#4
Thank you for responding Sander1.
This seems to be important section from the media server log:
Jan 06, 2018 15:10:43.243 [8700] DEBUG - [com.plexapp.system] HTTP reply status 200, with 1663 bytes of content.
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: analyzing media item -1
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): Direct Play is disabled
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): container is unavailable for analysis
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): no direct play video profile exists for http//
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): no direct play video profile exists for http///
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): codec is unavailable for analysis
Jan 06, 2018 15:10:43.244 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): no remuxable profile found, so video stream will be transcoded
Jan 06, 2018 15:10:43.245 [8700] DEBUG - Scaled up video bitrate to 2616Kbps based on 1.500000x fudge factor.
Jan 06, 2018 15:10:43.245 [8700] DEBUG - MDE: E11 - The Celebration Reverberation (from CBS): codec is unavailable for analysis
Jan 06, 2018 15:10:43.245 [8700] DEBUG - MDE: The Big Bang Theory - S11 E11 - The Celebration Reverberation (from CBS): selected media 0 / -1
Jan 06, 2018 15:10:43.245 [8700] DEBUG - Streaming Resource: Adding session 0BD3BF58:udbef4w4xys0c36biayeewmi which is using transcoder slot.  Used slots is now 1
Jan 06, 2018 15:10:43.246 [8700] DEBUG - Streaming Resource: Added session 0BD3BF58:udbef4w4xys0c36biayeewmi
**Jan 06, 2018 15:10:43.246 [8700] ERROR - PropertyContainer::get - invalid ratingKey value: http://www.cbs.com/shows/big_bang_theory/video/F2vHn782RqEkZ9wq1ekgPtvbcpjiqZjo/the-big-bang-theory-the-celebration-reverberation/**
Jan 06, 2018 15:10:43.246 [8700] DEBUG - Streaming Resource: Reached Decision id=-1 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=-1 part=(id=-1 decision=transcode container=mkv protocol=http streams=(Video=(id=1 decision=transcode bitrate=2616 encoder=libx264 width=1280 height=720) Audio=(id=2 decision=transcode bitrate=256 encoder=libopus channels=2 rate=48000))))
Jan 06, 2018 15:10:43.247 [16220] DEBUG - Completed: [127.0.0.1:53594] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Fsystem%2Fservices%2Furl%2Flookup%3Furl%3Dhttp%253A%252F%252Fwww.cbs.com%252Fshows%252Fbig_bang_theory%252Fvideo%252FF2vHn782RqEkZ9wq1ekgPtvbcpjiqZjo%252Fthe-big-bang-theory-the-celebration-reverberation%252F&mediaIndex=-1&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=1&session=ewca3x9jy7931aj6qrogmygb&offset=0&subtitles=auto&copyts=1&Accept-Language=en (9 live) GZIP 1474ms 1409 bytes (pipelined: 14)
This is also the first error in the sequence in any log. The other logs don’t have an error notification, only debug. After this the thread and transcoder dies.
In my case it says directplay is disabled. Is there a setting that I need to change?
#5
Thanks for the log! I see the exact same invalid ratingKey error in mine, even though video playback works for me :-?
CBS videos can’t be direct played because they’re in RTMP format, so the message about transcoding is correct.
Edit: Just checked some other channels that require transcoding and they also produce the same invalid ratingKey error in the log file, but playback works fine…
Edit 2: I also checked the CBS channel on Windows 10 (PMS 1.10.1.4602) and there the channel also works fine.
#6
Thanks Sander1. The next error is this:
Jan 06, 2018 15:10:47.913 [16364] ERROR - [Transcoder] Decoder (codec h264) not found for input stream #0:0
If CBS needs transcoding than this should explain an issue. Just don’t know how to fix it.
#7
I Googled the error message and did find some other posts, but not a solution :frowning: It looks to be a Plex Media Server or Transcoder (ffmpeg) error. At least it is not a channel error.
#8
I’ve experienced the same problem with CBS, but my logs have another error between the “invalid ratingKey” and the “decoder not found” that might help point to the issue:
ERROR - [Transcoder] RTMP_HashSWF: swfurl http://www.cbs.com/thunder/player/1_0/chromeless/1_5_1/CAN.swf not found
Same as @rjmulder , I am in US, not using VPN, and have latest version of PMS on Win10. I can play the Big Bang Theory video in browser from cbs.com no problem. I did capture page source from that browser window and saw this:
“playerPath”:"//can.cbs.com/thunder/player/chrome/cbscom/prod/vod/canplayer.swf"
To an ubernoob like me this seems to suggest some change at CBS? Eager to learn more from the PMS wise and venerable.
@qdev That’s some interesting information, thank you! I’ve updated the URL Service code and pushed out and updated Services.bundle (Plex Media server will download the update automatically).
#10
Thanks @sander1. Got the updated Service code, verified updated in AppData, restarted host machine and PMS, and while the swfplayer “not found” error is gone, still not playing CBS content for me.
No further insight at the moment, will update if I find something or becomes workee.
Log attached.
#11
Update: I now get a shaka1001 error playing Bull:
Playback Error
An error occurred trying to play “Grey Areas”.
shaka1001 (Network)
Same for a big bang episode.
#12
Playback Error
shaka1001 (Network)
“shaka” errors are thrown by the web player and usually have nothing to do with the channel itself. For good comparison please try the channel in a different Plex client (Plex Media Player for example) and see if it errors too.
#13
The answer is yes for one media server. I have a second one setup on win7 but the server is too slow, old beast what can I say. Anyway, on one server when trying for a cbs show I only get a spinning circle, and no progress indicator. On the other server I get Shaka1001 error but only for CBS channel. Bit annoying, other channels I can watch on-demand in other ways, CBS is the only one where I need plex…
