CBS shows no content
#1
Last week the CBS plug-in worked great. This week, when I go into the channel, it shows folders, but the folders are all empty. There is nothing to view. Any idea how to fix this?
#2
I’m unable to replicate. You can check the channel log file (com.plexapp.plugins.cbs.log) to see if there’s something reported in there.
#3
What specifically am I looking for in the log?
#4
Lines with CRITICAL show up in the log if something is broken. You can also zip the logs and post them for us to have a look.
#5
I don’t see anything listed as critical in my log.
#6
Can you upload the log files please?
#7
I am having the same issue and don’t know where to find the log file you mentioned, can you direct me to its location?
#8
https://support.plex.tv/articles/201106148-channel-log-files/
#9
I’m having the same issue. Please take a look at the attached files. Thank you!
#10
Same problem here.
2018-04-23 20:12:13,736 (e94) : DEBUG (runtime:814) - Found route matching /video/cbs/video
2018-04-23 20:12:13,746 (e94) : DEBUG (networking:161) - Fetching ‘http://www.cbs.com/carousels/videosBySection/238048/offset/0/limit/40/xs/0/31/’ from the HTTP cache
2018-04-23 20:12:13,769 (e94) : CRITICAL (core:574) - Exception (most recent call last):
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-215c28d86\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\components\runtime.py”, line 843, in handle_request
#11
I’m having the same issue. Please see the attached log files. Thank you
#12
@Stormside said:
Same problem here.
Please post full log files, not just snippets (attach them as a zip file to your post or post them to Pastebin).
#13
Thanks! I think I found the issue (plugin breaks when no summary is available for a video). A fix has just been pushed out. Your Plex Media Server will download this update automatically.
#14
Thank you
#15
I am having the same issue — here are my logs — thanks for your help
#16
Thanks! Had to download the init.py from github as it had not replicated yet.
Working great again! Thanks for the quick patch. :smiley:
#17
Mine is still showing empty folders. Do I need to do anything to get this to update on my server? I attached my logs as well.
#18
Also having the same issue after updating.
#19
That’s a very tiny log file without any errors in it… I have no idea what is going on there, and I cannot replicate the issue. Sorry :frowning:
#20
Thanks for the logs, it’s exactly the same issue which has been fixed, so PMS should pull in the updated plugin. Maybe try a restart of PMS to see if that picks up the change/update?
