Centering Poster Views?
night
#1
Is it possible to add the ability to center the selected movie/tv show when using Poster views as opposed to having the selected item on the far left?
#2
Sorry for the late reply but I don't check the subforum very often so it's better to use the existing "Feedback/Suggestion" thread instead ...
I'm not sure if I understand you correctly, do you mean the "sidebar" or just the poster image if an item is focused/selected? So, basically you want that the focused/selected poster image is always centered on the screen?
