Change keyboard shortcuts via custom input map?
plex-media-player
#1
I was attempting to change the keyboard shortcuts by creating a custom input map as instructed here but PMP doesn't seem to load the new mapping and instead continues to use the default mapping. Here is a short mapping I created to test
keyboard.json
json
"name": "Keyboard",
"idmatcher": "Keyboard.*",
"mapping":
"Left": "seek_backward",
"Right": "seek_forward",
"Shift\\+Left": "step_backward",
"Shift\\+Right": "step_forward",
"H": "play_pause",
#2
Since I can’t edit my post I guess I’ll put the extra info I forgot here:
Windows 10 Pro 64bit
Plex Media Player version 2.8.0
#3
same issue here. i was attempting to create a bind for mpv’s built in screenshot command.
#4
Binding a key won’t be enough to bind mpv commands. PMP will receive it but not forwards it to mpv if it’s not implemented :slight_smile:
