Would be great if this could be a setting I would like 30 second’s. Is this possible or apple locked.
I think it’s set by Apple. I get the same skip length, 10 seconds, in all my apps.
You can skip any amount if you use voice and say skip forwards or backwards and say what time period but that’s not convenient as you have to mute the TV for it to hear your command properly rather than a button click.
Mute the tv? Never had to do that before, when you hit the voice button it turns down the volume so it can hear you.
Never has on mine. I have been through all the menus when I got it earlier in the year in settings but maybe it is a new feature I need to turn on. It also has a lot of trouble understanding my voice for a lot of searches where everything else I own is Android which all understand my voice fine.
