Clean up photo upload (Temp location) on Nvidia shield.
server-nvidia-shield
#1
I look looking for a quick solution to clean up the temp folder that the Photo upload uses before it uploads the files to the final destination. I have been uploading my concert videos which are about 1.2GB a piece. I can cleanly see that my internal storage is growing with each file that gets upload. Couple of questions here.
  1. Can I clean up this location quickly with one of the options within Plex?
  2. Can I see these files and delete them within ES file Explorer?
  3. Will these get cleaned up in the Scheduled Tasks?
  4. Can I change the location of this folder to Adaptive Storage or External Storage?
  5. Why can't these files go to the 64GB drive instead of the 16GB internal storage?
I have a 64GB USB drive added for Adaptive Storage and a 256 SSD drive for External. With the new build, I have pushed my (Plex Meta Data) to the external drive.
#2
Could you provide some server logs after uploading these files?
The temporary files should be removed immediately when the upload is completed and gets moved to its final destination.
#3
I had to upload another video to get current logs. Really wish I could choose which files to upload. Now its just uploading dupes and puts a -1 after the file name. Also, I am up to 8GB on internal storage… seems like 6 large files are still hanging out there. I appreciate you guys looking into this and I know these files are suppose to be deleted right away, but can you try to answer my questions? I would like to clean this up ASAP.
#4
Can I get an update on this one? My shield is sitting at 8.9GB of app storage and I know it’s just like 6 videos that are just hanging out there. I have 12 more 1.2GB videos to upload but I can’t because it will fill up the internal storage and cause problems on my shield.
There should be a SIMPLE way to just clean up the temp folder… don’t even care if I have to do it a couple times while I am uploading these videos. Just give us the option.
#5
Still no update? I am on these forums daily… but why does it seem like some posts are barley looked at.
#6
Here is something interesting. I have been talking about how I have upload like 6 large 1.2GB videos and I can clearly see that under my internal storage it shows 8.9GB. However, if I go into ES File Explorer and look at the drives it shows I am only using 1.5GB of 64GB. What is also odd when I go into the Apps for internal storage and look under the Plex Media Server it shows 88.25GB but in the picture it only shows 81.15. Which seems VERY close to the 6 files. Why would it show in the apps size but not in ES Files Explorer. Just kind of weird.
#7
Well this is just F*#&ING great… Pretty sure my internal memory is filled up and I can’t upload ANYMORE pictures/videos…
I have done the move to external storage, I have set my TEMP transcode folder to the external storage but it still seems to be filling up the 16GB of internal storage and DOES NOT CLEAN IT UP!
CAN I GET A RESPONSE and can we clean the TEMP FOLDER UP?!?!?!?!
Logs are attached… LET me know if you need anything else.
2018/05/28 17:12:02.460 (141 MB) (449220) :heavy_minus_sign: PMKAssetController.m:304 | Video export completed successfully.
2018/05/28 17:12:02.479 (141 MB) (446878) :heavy_minus_sign: PMKCameraUploadEngine.m:1823 | Created data transfer task to check partial upload for 2018-05-18 21.32.21.MOV
2018/05/28 17:12:02.479 (141 MB) (446878) :heavy_minus_sign: PMKCameraUploadEngine.m:2190 | Ending background task.
2018/05/28 17:12:02.677 (141 MB) (443648) :heavy_minus_sign: PMKCameraUploadEngine.m:1320 | Beginning background task.
2018/05/28 17:12:02.678 (141 MB) (443648) :heavy_minus_sign: PMKCameraUploadEngine.m:2713 | Neither asset nor partial upload were found. Uploading from beginning.
2018/05/28 17:12:02.698 (141 MB) (443648) :heavy_minus_sign: PMKCameraUploadEngine.m:1828 | Created data transfer task to upload 2018-05-18 21.32.21.MOV
2018/05/28 17:12:02.699 (141 MB) (443648) :heavy_minus_sign: PMKCameraUploadEngine.m:2190 | Ending background task.
2018/05/28 17:12:02.736 (141 MB) (443648) :heavy_minus_sign: PMKCameraUploadEngine.m:1320 | Beginning background task.
2018/05/28 17:12:02.737 (141 MB) (443648) :heavy_minus_sign: PMKCameraUploadEngine.m:2762 | Something went wrong. Starting process over.
2018/05/28 17:12:02.737 (141 MB) (450191) :heavy_minus_sign: PMKCameraUploadEngine.m:1926 | Ending upload.
2018/05/28 17:12:02.737 (141 MB) (450191) :heavy_minus_sign: PMKCameraUploadEngine.m:1952 | In the middle of the upload process, attempting to finish up.
2018/05/28 17:12:02.737 (141 MB) (450191) :heavy_minus_sign: PMKCameraUploadEngine.m:1956 | No more tasks, all done.
2018/05/28 17:12:02.737 (141 MB) (450191) :heavy_minus_sign: PMKCameraUploadEngine.m:1987 | Upload ended.
#8
HI @ASiDiE
I haven’t had access to my Shield for the past week but I’m back now and will be seeing if I can reproduce your results on my end.
#9
Drzoidberg33,
Thank you! Let me know if you need anything else on this side.
#10
Any update on this? I did a factory reset on my shield and then moved how I upload photos to a plex server on my NAS device. Would be nice to be able to use the shield with all the options instead of having 2 servers out there.
