Collections show up between my movies
android-tv
fire-tv
#1
I have a Philips android TV with Plex on it. When I view my movies on this, movies and collections are both shown. Since Plex creates collections as well, a lot of collections just have one movie in it.
Because movies and collections are both shown, it just makes a very annoyingly long list.
Is there a way to show just movies? I know that on the top of the screen I can apply a filter, by default this is set to 'movies', the other option I have is 'collections'.
When it's set to 'collections', it just shows collections only. When I set it back to movies, movies and collections are shown.
How can I get a movies-only view?
#2
sure… use Plex Web, edit the settings of your movie library and change the collections option in the advanced settings to “deactivate” – this way no collection will show up inline with your movies.
as for your point on Plex automatically creating collections… this only happens if you configured it that way! double-check the following 2 configurations:
  1. agent settings (in general or for this library): do you have The Movie Database agent configured to download collection information? (checked Use collection info from The Movie Database)
  2. in Settings > Server > Agents > Movies check if you have the applicable agents configured to include embedded metadata… with this setting, Plex will include the “Album” tag from MP4/M4V files as “Collection”
#3
I just went to the web version of the app and added a '0 ’ prefix to the “Sort Name” of each collection and that moved the collections to the top of my page without changing the names.
I actually am finding I like the collections feature.
(oh, and deleted any collection that was pointless because it only had 3 or fewer movies in them)
#4
The idea of collections is nice, they just have a flawed implementation – one which I hope they realize & fix! Like the OP hinted, the collections should not be showing up in the movies view – leave them in the collections view! The current implementation treats the movies view as an ALL view.
#5
You can turn off that feature. Just edit your library and go to “advanced” section and choose the collection display option you want.
I keep the inline collection display off due to the bug where collections screw up the go to letter. At least until that BUG is fixed I will keep the inline display off but, in this case, it is good that Plex had the, unusual for them, foresight to allow the display option to be turned off.
