Commercial skipper broken after reinstall !?
After uninstalling Plex server (on Win 10 v1903) then deleting all remaining remnants of files that even looked like “Plex” or “PMS” and the same with a registry cleaner … …(several reboots later)
…I reinstalled PMS on to my A drive (A:…) (SSD) and set in Plex ” The path where local application data is stored” to “A:\Users@@@@@\AppData\Local”
Then I manually added my libraries and set the episodes back to there watched/unwatched status (this took several hours…)
The next day when I looked at the “DVR SCHEDULE” all recordings had the same error (something like “Post Processing Failed”) Yes this is about OTA recordings.
A Win reboot seamed to fix this… …BUT
Now the commercial skipper is not giving any errors (that I can see) but does not remove most commercials (anywhere near the way it did previously…)
Is this to do with my installation? Or have the broadcasters figured out how to fool the CS better?
P.S. USING:
HDHomeRun Quadro
Latest PMS on Win 10 v1903
Plex client on Roku, Fire tv 4K stick, local web (on( x.x.x.x:32400))
