Server Version#: Latest
Player Version#: Latest
Going to try and explain this one, if you’re viewing your library, then pick a show/Movie and just look at the Description or maybe the Cast & Crew, start browsing through the UI will reload, taking you back to the Top even though you were looking at something else. So if I just click on a show where I see the Episodes and dont touch the player “Nvidia Shield” it will just reload the UI over and over been doing this for quite some time not sure what to do here or consider a fix.
