coverflow in actual version
download from me
https://dl.dropboxusercontent.com/u/17115590/XML_templates.zip
extract it and it should work
same result, I think it was the same version I was using
1975jamie
I tried your link - It displays correctly as mentioned, however, when playing a movie (MKV), says "trailers is unavailable. Try again later"... Any idea here what needs to be done?
Do you have a log we can look at?
You should see it in all of them.
There is an issue in 0.1 where it will not show if you have less than 5 items/series but if you update to the latest source it has been fixed.
Yeah I have tried the latest one from here: http://goo.gl/lOlu8, elan's from here: http://goo.gl/dXuksO, and so long as I have categorized something as a TV Show on my PMS, PlexConnect on my AppleTV 3 will not display coverflow.
At the end of the day, I am over the moon with this creation, and am in no need for this to be fixed. It looks cool and that's all. I can still access those shows like I had always wanted to and that is all that matters.
Are you sure you are hitting the download as zip button on the right?
You should end up with a zip file you need to uncompress.
Does movies show like it should.
1975jamie
I did not change anything. Just download it and then upload to Dropbox.
I don't use MKV movies sorry.
edit.  I do have these movies. no problem playing them.
Yes that is correct
1975jamie
Are these itune download movies?
I think that all iTunes movies are in .mp4, no?
no they are in MKV
MY mistake it m4v.  never mind
ITunes purchased content is always .m4v which is an expanded version of mp4. iTunes store does not supply content in the mkv format.
yes that right. I was thinking wrong. My mistake.  That what happens when you just wake up and try to answer this. The mind was not working yet.
Can you take a screenshot of your PlexConnect folder please?
Also where is it located (e.g. in C:/)?
And the assets folder contents?
Could you also show the extensions for the files please.
Hmm it looks as if you have everything there.
What application are you using to unpack the zip file?
How many TV shows do you have in that section?
Winrar was used to unpack it, and I have anywhere from 12-20 shows in there.
Try downloading a fresh copy and unpacking it using windows itself - it is worth ruling it out even though i am not confident that it is the problem.
Hey, Geoff, in all the posts you've made, I haven't seen you list any relevant debug info like:-
Which version of PMS are you running? (If you have supplied this info and I've just missed it then I apologize)
You need the latest version of PMS as it contains the stacked library requests which the TV art makes use of.
