Crash when looping music
windows-store-app
#1
I've encountered a problem with the Windows store app crashing when I play music, specifically when looping. It is pretty easy to reproduce at least on my setup.
Steps to reproduce:
* Open the app
* Log in (I am admin, if it makes a difference)
* Start playing a song
* Press the repeat button until the single track loop is selected (icon with a '1' in the corner)
* Minimize the window
* Wait about 10 seconds (definitely less than 30)
Since I've never had a problem with Plex before, I don't know if there are any logs that I should be posting?
I am using Windows 10 on a desktop PC.
Any solutions or workarounds would be appreciated.
#2
Disappointed this hasn't had an official response in two months (should be a simple fix) but here is a workaround for anyone else having the issue:
Keeping the player open (but behind other windows) doesn't cause the crash. It's only if you minimize the window.
#3
Don't minimize the window, or change your displays zoom from 150 to something else...
