Hey @ChuckPa - no connectors. At the moment the only 2 “auto deposits” are Sonarr and Plex DVR. What’s the recommendation for Sonarr then? This was working fine before, and… I hate to say this, but I just did an update to the Synology (DSM 6.2.4-25556) and I was shocked to see it still up this morning.
I use Connectors for Sonarr media post-processing. This occurs before the media is placed in the TV library directories.
I do not have Sonarr interface with Plex. Allowing the kernel Notify service to do its job is best .
No Sonarr connectors.
It downloads then moves things over:
I had another crash but no dump was created. I attached the logs: Logs.zip (2.0 MB)
I can disable Sonarr for a week and see how things go - Does my config match what you’re suggesting?
One last question: I’m trying to look at the file time created on the imported to match the “crash” time in the logs. What log do I look into in order to find a “termination” time, maybe a log that carries a heartbeat that I can even look to see “this is the last time it was written to”?
I went with option 1! I’ll keep Sonarr on and see what happens! Thanks! Step 2, more logs and disable Sonarr!
Had another crash - Will be disabling Sonarr. Standby. Out of curiosity - what are people using as their NZB client? Saz has been giving me some issues as of late.
Another crash - Should I consider removing my PlexDVR also? I flushed the database too as per the instructions (putty’d in, etc)
Logs-NoSonarr.zip (4.0 MB)
let me have a look at this. Thanks again Trumpy
Question - Why would I have .ts files? What are they used for ?
Is there a way to change the recording format from mpeg2 for the HDHomerun connect? I’ve just brought things back online after all the renames…
So far so good. I’ll be adding the DVR today.
