Customizing your Plex configuration
server-linux-tips
#1
Customizing your Plex configuration on systemdbased systems
This information is intended for those systems where cat /proc/1/comm returns systemd.
On systems which use Systemd (Ubuntu 16+, Fedora, Centos 7, Debian 8,) you create this customization file which SystemD reads prior to launching PMS. This file is independent of the default configuration and service control mechanisms in /lib/systemd/system/plexmediaserver.service. Your customization override is preserved across updates, uninstall, re-install operations.
If your system returns init, please edit the values in /etc/defaults/plexmediaserver
While you may change /lib/systemd/system/plexmediaserver.service, it is under the control of the package manager and subject to replacement without warning at any time during an update. To provide stability, systemd allows creation of an override.conf file to customize and create enduring local adjustments to a distributed default package.
You can change a number of parameters about how PMS runs on your Linux system including where the metadata (Library) resides.
The most common, and safest, parameters you can change are:
  1. Environment variables.
  2. Username PMS uses at runtime
  3. Group name PMS uses at runtime
All Environment variable specifications are of the forms:
Environment="VARIABLE_NAME=literal string here. spaces are allowed"
or
Parameter=value
Example: Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/home/plexdir/Application Support"
Example: User=chuck
The Plex-supplied service definition should not be modified as any changes are subject to overwriting at every update.
The task, with PMS stopped, is:
  1. Create the ‘override’ file in directory /etc/systemd/system/plexmediaserver.service.d
  2. Move any files if needed
  3. Change ownership if needed
  4. Inform systemd of the changes
  5. Start PMS
In the example below, the following will be shown. Tailor to your environment as needed
a) Run as user chuck:chuck
b) Move the metadata (Library) to /home/plexdir for the extra space
c) Relax the default file-creation permissions (for plug-ins, etc)
Warning: /media is reserved by Gnome and Gnome’s Nautilus file browser
The following steps must be done as root, elevate first and get a full shell to work in
sudo sh
Begin here:
A. Create directory /etc/systemd/system/plexmediaserver.service.d. In it, create override.conf containing the following
# Customize Plex's config
# Identify this as a service override
[Service]
#  Move the data directory
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/home/plexdir/Library/Application Support"
#  These values are only needed if you wish to change user & group
User=chuck
Group=chuck
# This is needed to change the default umask
UMask=002    # this must be octal    - See warning below
Warning:
Some distros used UMask while others use Umask
Some distros want 4 octal digits, not the standard 3. Go figure
Please be cautious of this on your system.
B. Inform SystemD of the changes and test the related & reconfigured PMS
systemctl daemon-reload
systemctl start plexmediaserver
C. Test your system. Verify everything is exactly as it was. If not, resolve before proceeding
http://127.0.0.1:32400/web
Administration note:
Once you have created the override file, you can later edit it with systemctl edit plexmediaserver
Supplemental Shortcut
If you have only a few customizations to make, you may opt to let systemctl make the files for you
  1. sudo systemctl stop plexmediaserver
  2. sudo systemctl edit plexmediaserver
  3. Enter the same override information as shown above
  4. Save and exit the editor
  5. sudo systemctl daemon-reload
  6. Perform any required ownership / other work required
  7. sudo systemctl start plexmediaserver
Update creates 'new server'
Can't find 'plex' user
[linux] Cant add any library
Deb package
Latest update broke plex
#2
