DEB-based repository is not up to date
server-linux
#1
Plex download page shows as latest public version 1.13.2.5142-3ba6662e9 from June 6, 2018
If I run sudo apt-get update && apt-cache madison plexmediaserver it shows as latest version
plexmediaserver | 1.13.0.5023-31d3c0c65 | https://downloads.plex.tv/repo/deb public/main amd64 Packages
The server is configured as shown in the support article.
I saw in an old question this has happened before, and required a large hammer to fix...?
#2
Everything is correct on your side. Please be patient. It’s just a small server “hickup”. Just install the package manually if you need the update NOW, e.g. sudo dpkg -i plexmediaserver_1.13.2.5142-3ba6662e9_amd64.deb.
#3
We might have to wait until Monday for the CI team to fix it. I don’t have access to those systems.
If you want 1.13.2.5142, it is available from plex.tv/downloads
#4
Was this fixed?
I’m still having the same issue.
#5
The warning exists. When we finish updating the CI, the repository warning will go away (which i’m working on right now). I am also on the CI team.
The correct entry in the sources.list file should be public main. ./public main will result in an error
