Server Version#: 1.43.0.10389
Tuner Make/Model: TvHeadend + xTeVe
Guide/Lineup name: Plex Guide
Using XMLTV?: yes
Channel number/Name:
I was reconfiguring my TvHeadend and xTeVe Proxy.
Plex failed reaing the EPG, so i deleted the DVR config and tried to add again.
TvHeadend and xTeVe are running fine, i can already watch Live TV with my Sony TV Box.
But when i try to add it again to Plex, every single time it fails to map and update the EPG.
I also tried different configurations: TvH as HDHomerun, TvH as SAT/IP, xTeVe with PMS EPG, xTeVe with XEPG, XMLTV from differnent providers etc..
Every try ends with this lines in the Server Log:
Jan 04, 2026 00:50:13.131 [140154176760632] INFO - [Req#8ac9] Completed forward migration 202205091600.
Jan 04, 2026 00:50:13.131 [140154176760632] INFO - [Req#8ac9] Running forward migration 202205091700.
Jan 04, 2026 00:50:13.133 [140154176760632] INFO - [Req#8ac9] Completed forward migration 202205091700.
Jan 04, 2026 00:50:13.133 [140154176760632] INFO - [Req#8ac9] Analyzing database.
Jan 04, 2026 00:50:13.134 [140154176760632] INFO - [Req#8ac9] Vacuuming database.
Jan 04, 2026 00:50:13.134 [140154176760632] ERROR - [Req#8ac9] SQLITE3:0x80000001, 6410, statement aborts at 5: [CREATE TABLE “media_parts” (“id” INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL, “media_item_id” integer, “directory_id” integer, “hash” varchar(255), “open_subtitle_hash” varchar(255), “file” varchar(255), “index” integer, “size” integer(8), “duration” integer, “created_at” dt_integer(8), “updated_at” dt_integer(8), “deleted_at” dt_integer(8), “extra_data” varchar(255))] disk I/O error
Jan 04, 2026 00:50:13.134 [140154176760632] ERROR - [Req#8ac9] SQLITE3:0x80000001, 10, statement aborts at 1: [VACUUM] disk I/O error
Jan 04, 2026 00:50:13.136 [140154176760632] ERROR - [Req#8ac9] Exception thrown during migrations, aborting: sqlite3_statement_backend::loadOne: disk I/O error
That table already exists, btw.
Any ideas?
