Disabling subtitle in Plex VR
plex-vr
#1
Seems that there's no support for subtitles in PlexVR.. this causes odd problem for me.. Plex server fails to transcode (not powerful enough) Usually what I can do on my appletv client is disable subtitles if transcoding is needed (Rarely an issue since appletv handles subrip SRT subs easily)
There doesn't seem to be such an option in Plex VR ?
#2
Yeah there is not yet. You would have to set subtitles for that item to none in the Web app and then all other apps should follow that same setting.
#3
Oh, i can set default on the movie that way. I thought it was for web-player only. Will give it a try. Thanks !
