Thats correct. No posters showing for 5 Latest Movies or names.
But they do if I go into the Plex DB
@lexus232 I was still setting it up. I didn’t fully set it up because I had just switched back to Plexredirect.
alright then
I’ve just made the call to the API and it doesn’t return any movies, probably because I’ve not added any recently. lol
I’ve changed the count to 50 to see it that works.
may be because of that. also, chmod 777 posters and cache in the inc folder. so the imdb class can save the posters. also, if that does not work, try to grab the plexfeed script and see if that returns anything, though I doubt it, because they’re pretty much the same.
@Deja.Vu it works. I just went to your site and it shows the movies.
you were right, you didn’t add movies lately. however I wrote the script for myself and I always add movies. i will release an update with the changed $count so others do no encounter the same issue. . thanks for the heads-up
Loving this script, but I think I’m going to rearrange stuff a little. I think the Status personally, should be at the top.
No point trying to load the content pages if it reports its down from the off.
Also another heads up - I think your domain is Hardcoded into the ‘Access Plex Here’ bit.
index.php line 120
right, forgot about that line. but, i would see it as “soft-coded”. after all , it;s just html. modify it whatever you like. i am more than happy to see new designs.
also, love to hear that you like it
I have my site up and running, but it looks like I need to go back and tweak some of my variables. This is awesome though. Thanks for your work!
So nice, can you create a github repository for it ? Thanks you
@Jig_Saw . sure thing
@coolhandluuk thank you
also, no problem .
@Jig_Saw here is the repo: github.com/alexanderthegreat96/plexdash
Any changes to the plex_db folder in v1.2? @lexus232
not that I am aware of :)) so no @jrdnlc
Had some time to take a look at this again, updated to version 1.5 / 1.6 (updated to 1.6)
Running on apache 2.2, PHP 5.5
I get 2 elements that load, compared to before / forum screen shots.
I have server online reachable, and last 5 movies added.
Everything else is not loaded. This might be my environment, but i can load plexpy, plex media server web, plex requests outside of Plex Dash fine, but plex dash dose not load them.
some things i still see, double url’s when i mouse over /hover over links; that look like “http://URLNAMEhttp://URLNAME” clicking the link for where [SERVER NAME] should be puts me at my main URL; is that supposed to take me to my root website, or my plex media server web page?
In your config example, your plex media server and plexpy URL’s are on sub domains? is that required? my setup dose not use any sub domains.
@m1e1w1 of course not it is not required to map services under subdomains. you can use ports as well. why they don’t load , i do not know. maybe theyre not enabled in dash_config.php . make sure everything is configured properly. maybe i can configure it for you. let me know if you would like to set me up with VNC
@lexus232
I don’t mind using VNC, but i will need to wait till Sunday to do that; my work schedule has me busy the rest of this week. I appreciate you taking the time to take a look at my environment though.
@m1e1w1 of course, no problem. PS: are you on apache or nginx?
