DLNA no longer working
server-dlna
#1
My Sharp Aquos TV has recently stopped working with Plex via DLNA. I've attached the 2 logs after enabling debug logging, and restarting the server. I then recreated the issue on the TV and have attached the logs. When I select a show to play on the TV it attempts to start playback and almost instantly flips me back to the video listings (failing to play video).
Apr 08, 2017 14:56:07.419 [3172] DEBUG - Codecs: testing aac_mf (decoder)
Apr 08, 2017 14:56:07.419 [3172] WARN - Failed to find decoder 'aac_mf'
Apr 08, 2017 14:56:07.420 [3172] DEBUG - MDE: received PLEX_PROTOCOL_ANY from client, selected protocol http
Apr 08, 2017 14:56:07.420 [3172] DEBUG - MDE: analyzing media item 12787
Apr 08, 2017 14:56:07.420 [3172] DEBUG - MDE: E9 - Dead in the Water: no direct play video profile exists for http/mkv/h264
Apr 08, 2017 14:56:07.420 [3172] DEBUG - MDE: E9 - Dead in the Water: no direct play video profile exists for http/mkv/h264/aac
Thanks in advance for the help!
#2
Does anyone have any thoughts?
#3
Same here on my 2011 Sharp Aquos. Any file that needs to be transcoded just kicks me back to the file listing. I've tried playing around with the profile and cannot get it to work :/
#4
It's definitely profile related. I also run servvio and they fixed the issue for me in 1hr. Instructed me to remove a line from their profile, and I'm back up and running...
#5
Could you please post the profile?
#6
Here it is
