EAE timeout! EAE not running, or wrong folder?
server-docker
#1
I'm also having trouble with EAE using latest docker image. It appears to be using tmp, which has all permissions available. Haven't had a problem like this until 1.5.x. Log and subsequent info below:
I also noticed that EAE is using /tmp instead of my set transcode folder. Given the highly configurable nature of a docker container (and the potential horrible performance implications of /tmp being on an overlay filesystem, I would definitely hope that EAE would honor the set transcode folder settings (or provide a way to specify the EAE transcode folders).
My transcode folder is set to /config/transcode (and I've verified it is being used). Although, the incorrect use of /tmp does not explain the problem as a whole, just a side note.
Apr 22, 2017 23:35:52.000 [0x7f09873fe700] ERROR - [Transcoder] [ac3_eae @ 0x16f1560] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to WAV (to 8ch or less)/7jpjb945mywgwxq4j60x82kk_8446-1-3.wav'
Apr 22, 2017 23:35:52.006 [0x7f097c3fb700] ERROR - [Transcoder] [ac3_eae @ 0x16f1560] error reading output
Apr 22, 2017 23:35:52.016 [0x7f09687fe700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
root@plex-1689959742-tdhls:/tmp# ls -alR /tmp
/tmp:
total 12
drwxrwxrwt 1 root root 4096 Apr 22 23:35 .
drwxr-xr-x 1 root root 4096 Apr 21 09:38 ..
drwxrwxrwx 3 root plex 4096 Apr 22 23:26 pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa:
total 12
drwxrwxrwx 3 root plex 4096 Apr 22 23:26 .
drwxrwxrwt 1 root root 4096 Apr 22 23:35 ..
drwxr-xr-x 8 root plex 4096 Apr 22 23:26 EasyAudioEncoder
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder:
total 32
drwxr-xr-x 8 root plex 4096 Apr 22 23:26 .
drwxrwxrwx 3 root plex 4096 Apr 22 23:26 ..
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital (High Quality - 640 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital (Low Quality - 384 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital Plus (High Quality - 384 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to Dolby Digital Plus (Max Quality - 1024 kbps)
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 Convert to WAV (to 2ch or less)
drwxr-xr-x 2 root plex 4096 Apr 22 23:35 Convert to WAV (to 8ch or less)
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital (High Quality - 640 kbps):
total 8
drwxr-xr-x 2 root plex 4096 Apr 22 23:26 .
drwxr-xr-x 8 root plex 4096 Apr 22 23:26 ..
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital (Low Quality - 384 kbps):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital Plus (High Quality - 384 kbps):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to Dolby Digital Plus (Max Quality - 1024 kbps):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to WAV (to 2ch or less):
total 8
/tmp/pms-42850147-8bbc-4a27-8f0e-f5a1329d9caa/EasyAudioEncoder/Convert to WAV (to 8ch or less):
total 80
drwxr-xr-x 2 root plex 4096 Apr 22 23:35 .
-rw-r--r-- 1 root plex 35840 Apr 22 23:35 7jpjb945mywgwxq4j60x82kk_8446-1-6.ac3
-rw-r--r-- 1 root plex 35840 Apr 22 23:35 7jpjb945mywgwxq4j60x82kk_8446-1-7.ac3
root@plex-1689959742-tdhls:/tmp# ps auxwwwf
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 6269 0.0 0.0 20060 3392 ? Ss 22:50 0:00 /bin/bash
root 8463 0.0 0.0 36128 3108 ? R+ 23:36 0:00 _ ps auxwwwf
root 1 0.0 0.0 196 4 ? Ss Apr21 0:00 s6-svscan -t0 /var/run/s6/services
root 23 0.0 0.0 196 4 ? S Apr21 0:00 s6-supervise s6-fdholderd
root 265 0.0 0.0 196 4 ? S Apr21 0:00 s6-supervise plex_advertise_dns_update
root 268 0.0 0.0 19980 3372 ? Ss Apr21 0:03 _ bash ./run
root 8461 0.0 0.0 6084 748 ? S 23:35 0:00 _ sleep 60
root 266 0.0 0.0 196 12 ? S Apr21 0:00 s6-supervise plex
root 6393 0.0 0.0 4508 756 ? Ss 22:53 0:00 _ /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver /usr/lib/plexmediaserver/Plex\ Media\ Server
root 6395 3.7 0.2 768840 68076 ? Sl 22:53 1:35 _ /usr/lib/plexmediaserver/Plex Media Server
root 6407 0.4 0.2 1797328 64624 ? SNl 22:53 0:10 _ Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/System.bundle
root 6454 0.0 0.0 438316 5964 ? Sl 22:53 0:00 _ /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.5.5.3634-995f1dead 32600 /waitmutex
root 6953 0.4 0.1 356224 39036 ? SNl 23:04 0:07 _ /usr/lib/plexmediaserver/Plex Media Scanner --index --analyze --section 1 --log-file-suffix Analysis
root 7128 0.5 0.1 1171224 43920 ? Sl 23:12 0:07 _ Plex Plug-in [com.plexapp.agents.thetvdb] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/TheTVDB.bundle
root 7193 0.1 0.1 1023196 33680 ? Sl 23:12 0:02 _ Plex Plug-in [com.plexapp.agents.plexthememusic] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/PlexThemeMusic.bundle
root 7217 0.4 0.1 951228 35496 ? Sl 23:12 0:05 _ Plex Plug-in [com.plexapp.agents.opensubtitles] /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.5.5.3634-995f1dead /usr/lib/plexmediaserver/Resources/Plug-ins-995f1dead/OpenSubtitles.bundle
root 8037 0.0 0.0 21576 2180 ? S 23:26 0:00 _ Plex EAE Service
root 8325 15.2 0.1 809260 51208 ? SNl 23:32 0:34 _ /usr/lib/plexmediaserver/Plex Transcoder -codec:v h264 -i /data/Media/Shows/Firefly/Season 01/Firefly - S01E02 - Bushwhacked [720p, x264, AAC].mkv -threads 0 -nostats -q 3 -loglevel quiet -progressurl http://127.0.0.1:32400/video/:/transcode/session/bif/progress -filter_complex [0:V:0] scale=w=320:h=240:force_original_aspect_ratio=decrease [out] -map [out] -r 0.5 /config/Library/Application Support/Plex Media Server/Media/localhost/e/95cb461ede08a743fc8adec464f02a6e9d4944e.bundle/Contents/Indexes/tmp/img-%06d.jpg
root 8442 4.8 0.1 307212 55276 ? SNl 23:35 0:04 _ /usr/lib/plexmediaserver/Plex Media Scanner --scan --refresh --section 2
root 8446 39.7 0.0 221960 21744 ? Rl 23:35 0:27 _ /usr/lib/plexmediaserver/Plex Transcoder -codec:0 h264 -codec:1 ac3_eae -eae_prefix:1 7jpjb945mywgwxq4j60x82kk_ -noaccurate_seek -i /data/Media/Shows/Lethal Weapon/Season 01/Lethal Weapon - S01E03 - Best Buds [720p, x264, AC3, HDTV].mkv -map 0:0 -metadata:s:0 language=eng -codec:0 copy -map 0:1 -codec:1 aac -ar:1 48000 -channel_layout:1 stereo -b:1 256k -f segment -segment_format matroska -segment_format_options live=1 -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list http://127.0.0.1:32400/video/:/transcode/session/7jpjb945mywgwxq4j60x82kk/seglist -segment_list_type csv -segment_list_size 2147483647 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 chunk-%05d -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/7jpjb945mywgwxq4j60x82kk/progress
root@plex-1689959742-tdhls:/tmp# df -h
Filesystem Size Used Avail Use% Mounted on
overlay 19G 5.6G 13G 32% /
tmpfs 15G 0 15G 0% /dev
tmpfs 15G 0 15G 0% /sys/fs/cgroup
/dev/xvdbb 118G 18G 95G 17% /config
/dev/xvdbc 246G 128G 107G 55% /data
/dev/xvda1 19G 5.6G 13G 32% /transcode
shm 64M 8.0K 64M 1% /dev/shm
tmpfs 15G 12K 15G 1% /run/secrets/kubernetes.io/serviceaccount
Local:Vault 1.1P 128G 1.1P 1% /data/Media
ACD_VAULT:/Media 1.0P 0 1.0P 0% /data/.Vault
#2
Given the lack of logs, I have to guess that your issue is the same as this one: https://forums.plex.tv/discussion/comment/1409740/#Comment_1409740
#3
I'll give the fix a try, see if it resolves, and let you know. Thanks!
#4
I have the same error, here are the logs
#5
I ended up reinstalling the official docker container (previously was using the linuxserver.io docker container) and all works.
#6
I'm still having issues with anything past 1.5.1.
After some period of time:
Jun 02, 2017 10:56:38.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-31.wav'
/tmp has all the right permissions, but I also hope /tmp would not be used as my transcode directory is set to /config/transcode (a special ssd volume).
I have also increased the number of watches per another thread:
sysctl -w fs.inotify.max_user_watches=100000
Full Log:
Jun 02, 2017 10:55:05.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-0.wav'
Jun 02, 2017 10:55:05.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:05.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:08.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-1.wav'
Jun 02, 2017 10:55:08.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:08.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:11.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-2.wav'
Jun 02, 2017 10:55:11.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:11.003 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:14.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-3.wav'
Jun 02, 2017 10:55:14.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:14.002 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:14.303 [0x7fefaefff700] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2017 10:55:17.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-4.wav'
Jun 02, 2017 10:55:17.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:17.002 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:20.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-5.wav'
Jun 02, 2017 10:55:20.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:20.003 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:23.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-6.wav'
Jun 02, 2017 10:55:23.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:23.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:26.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-7.wav'
Jun 02, 2017 10:55:26.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:26.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:29.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-8.wav'
Jun 02, 2017 10:55:29.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:29.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:30.803 [0x7fefaefff700] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2017 10:55:32.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-9.wav'
Jun 02, 2017 10:55:32.002 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:32.003 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:35.000 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-10.wav'
Jun 02, 2017 10:55:35.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:35.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:38.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-11.wav'
Jun 02, 2017 10:55:38.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:38.003 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:41.000 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-12.wav'
Jun 02, 2017 10:55:41.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:41.002 [0x7fef84ffd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:44.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-13.wav'
Jun 02, 2017 10:55:44.001 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:44.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:47.000 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-14.wav'
Jun 02, 2017 10:55:47.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:47.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:47.284 [0x7fefae7fe700] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2017 10:55:50.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-15.wav'
Jun 02, 2017 10:55:50.002 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:50.003 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:53.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-16.wav'
Jun 02, 2017 10:55:53.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:53.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:56.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-17.wav'
Jun 02, 2017 10:55:56.002 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:56.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:55:58.788 [0x7fef9ebff700] ERROR - Throttle: timed out trying to read chunk -1
Jun 02, 2017 10:55:59.002 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-18.wav'
Jun 02, 2017 10:55:59.003 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:55:59.007 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:02.000 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-19.wav'
Jun 02, 2017 10:56:02.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:02.002 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:03.776 [0x7fefae7fe700] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2017 10:56:05.000 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-20.wav'
Jun 02, 2017 10:56:05.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:05.002 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:08.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-21.wav'
Jun 02, 2017 10:56:08.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:08.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:11.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-22.wav'
Jun 02, 2017 10:56:11.002 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:11.003 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:14.000 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-23.wav'
Jun 02, 2017 10:56:14.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:14.002 [0x7fefa1bfd700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:17.001 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-24.wav'
Jun 02, 2017 10:56:17.002 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:17.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:20.000 [0x7fefa63ff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-25.wav'
Jun 02, 2017 10:56:20.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:20.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:20.248 [0x7fefae7fe700] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2017 10:56:23.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-26.wav'
Jun 02, 2017 10:56:23.002 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:23.002 [0x7fefaffff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:26.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-27.wav'
Jun 02, 2017 10:56:26.001 [0x7fefaffff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:26.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:29.000 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-28.wav'
Jun 02, 2017 10:56:29.001 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:29.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:32.000 [0x7fefa1bfd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-29.wav'
Jun 02, 2017 10:56:32.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:32.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:35.000 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-30.wav'
Jun 02, 2017 10:56:35.001 [0x7fef85fff700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:35.002 [0x7fefa63ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:36.738 [0x7fefaefff700] ERROR - EventSource: Retrying in 15 seconds.
Jun 02, 2017 10:56:38.001 [0x7fef84ffd700] ERROR - [Transcoder] [ac3_eae @ 0x201d3c0] error reading output
Jun 02, 2017 10:56:38.002 [0x7fef85fff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jun 02, 2017 10:56:40.847 [0x7fefb13ff700] ERROR - JobManager: child process killed by signal: 9 (Killed)
Jun 02, 2017 10:56:40.891 [0x7fefaefff700] ERROR - [TranscodeOutputStream] Streaming Session 0x7fefa2cebce0 appears to have died from under us
Jun 02, 2017 10:56:40.915 [0x7fef87fff700] WARN - Got a request to stop a transcode session without a session GUID (or with an invalid one).
#7
To add, a quick visual inspection of the /tmp directory showed .a number of the files being asked for there (and then would vanish):
root@plex-4286764477-lwdkf:/tmp# find
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital (Low Quality - 384 kbps)
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-12.ac3
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 8ch or less)/h54q8lb4ged9cozo2lhewgsm_839-1-13.ac3
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital Plus (Max Quality - 1024 kbps)
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to WAV (to 2ch or less)
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital Plus (High Quality - 384 kbps)
./pms-36605dbd-59e0-4612-a44e-bfb61daa3e36/EasyAudioEncoder/Convert to Dolby Digital (High Quality - 640 kbps)
#8
Consolidating on to:
https://forums.plex.tv/discussion/268897/error-transcoder-ac3-eae-0x2fd4f40-eae-timeout-eae-not-running-or-wrong-folder#latest
