Edit or Delete a Collection
plex-web
#1
Hi guys,
I kept looking for a solution or an answer, but couldn't find anything.
1. How an item is removed form a collection?
2. How a collection title is renamed?
3. How a collection is deleted?
Thank you in advance!
#2
Never mind, I believe all the above actions aren't implemented yet. Everything still can be done using the old media manager by option+opening it.
#3
[s]Wonder how can i do this on windows(from web interface i think)? Do i have an option to at least remove movie, that was added to the collection by mistake, from the collection?[/s]
Never mind. Found the solution here: http://wiki.plexapp.com/index.php/PlexNine_PMS_MediaManager#Collections
Collection is removed automatically if it doesn't contain any movies.
#4
Yes - 0x49D1 but the process of removing the movie is at least 7 clicks:
Process:
  1. Click collection list
  2. Click collection list title
  3. Click pencil to enter edit mode (movie profile)
  4. Click X to delete collection
  5. Click save
  6. Click back button to get back to collection list
  7. Click collection list to remove
I wouldn't much mind doing the following steps for 1 or 2 movies that were added by mistake however I rebuilt my Plex server on OS X and Plex created a collection list and about 30% are single movies . I have tried to go directly to the collection list and uncheck the box but that did not work or I'm not clever enough to figure out how to work it.
It would be nice if a simple delete collection list function was added :)
#5
Collections will be getting a makeover in the (hopefully near) future.
#6
That will be awesome ericmatthys!
#7
Great, I love collections like
Criterion Collection
James Bond
Best Picture (oscar winners)
Studio Ghibli, Pixar, Dreamwork's (I know i can use studio filter but...)
etc.
The only way to rename a collection is to create a new and delete all the titles, one by one from wrong collection, correct?
#8
James Bond
Studio Ghibli, Pixar, Dreamwork's (I now i can use studio filter but...)
etc.
Sadly, yes. Collections desperately need some love.
#9
+1
Where does this rank on the roadmap for PlexWeb.. the issues laid out in this thread are easily reproducible, and definitely need some attention.
That said, PlexWeb is very very slick.  It makes me want to learn ember.
-mm
#10
+1
-mm
We don't discuss our roadmap openly for a few reasons (expectations, competition, etc).
Plex/Web actually uses Backbone, but Ember is a good place to start too. :)
#11
Is there still no way to delete a Collection? This is why I miss the cocoa media manager :(
#12
+1 for the old Cocoa manager. "If it ain't broke, don't fix it." The Cocoa manager had all these functions that we want/need. Please bring it back! It was also much faster at managing large collections. I currently have over 2000 movies, managing with a web front can be very tedious.
#13
It ain't coming back. I kept a copy of the old PMS in ~/Applications. When I need to do a lot of library management, I quit the new PMS and use the Cocoa manager from the old one.
#14
Process:
  5. Click save
So, this does work, but it doesn't truly "delete" a collection. It hides it.
For example, I made the mistake of not capitalizing the r in "rambo," and there is no way for me to change that. I deleted the rambo collection following these steps, and it fully disappears. But when I try to create a collection called "Rambo" and add movies to it, it stays as "rambo" in my collections list. It's actually quite annoying because it's the only of all of my collections that is not capitalized. I guess I could rename the collection to Rambo series or something like that, but it is not consistent with how I've named my other collections. I'll just have to deal with a little rambo. Which doesn't give the series justice; if any should be capitalized, it's Rambo!
#15
You can fix that with a little SQLite magic.
UPDATE tags SET tag = "Rambo" WHERE tag = "rambo";
#16
MovieFan, could you elaborate what I would need to do? I have a Mac. Do I need SQLite editor, or can I edit a text file somewhere? Or is there a terminal command? Whatever you think is easiest. Thank you.
#17
I think SQLite is built in to OSX.  You would just use the terminal command.
sqlite3 ~/Library/Application\ Support/Plex\ Media\ Server/Plug-in\ Support/Databases/com.plexapp.plugins.library.db "UPDATE tags SET tag = 'Rambo' WHERE tag = 'rambo';"
The ending is single quote semicolon double quote in case you cannot tell.
It is always recommended to quite Plex when messing with the database, but I find this modification to be pretty harmless and have not run into any problems doing this with Plex running.
#18
That worked perfectly and so easily! Thank you very much!
#19
Exactly what I was looking for, except...
Now I'm running the server on a Windows (8.2) machine. Any hints how to do the same there?
#20
Easy way to access the database on a Windows machine is via Firefox addon - https://addons.mozilla.org/en-US/firefox/addon/sqlite-manager/
