elans GUI fork TV On Deck no content showing
Hi
I know the fork is not fully supported however could anyone confirm that the TV shows on deck section works for them. Everything else works for TV and movies but when on deck is selected i just get the spinning icon and "Accessing Trailers" message.
I have included my terminal output in the link below.
http://pastebin.com/N963DjWu
  • ATV2
  • Your ATV firmware version: 5.2
  • The DNS server set on the ATV:192.168.1.11
  • The device and operating system (including version number) that PlexConnect is installed on: OSX 10.8.4 Mac Mini
  • The local IP address of the device that PlexConnect is installed on: 192.168.1.11
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: OSX 10.8.4 Mac Mini PMS 0.9.7.22
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.11
  • Where your media is stored: external drive
  • The PlexConnect version number (or if using Github source then a time and date of download; look at the creation date of the folder):Elans GUI Fork downloaded 1 hour ago.
Can you check to see if any of you on deck items have missing actor/director/genre info missing?
If so it is a known bug, you can test by editing the data to see if it makes a difference.
Roidy and elan have been discussing something like this in the comments section of the pull request on Github. Seems to be an issue that appears if you do a specific series of things.
"roidy commented:
Go to the On Deck section, select an item and then navigate back to the On Deck section so the xml reloads, now press up on the remote and the navbar is meant to appear but it doesn't."
Sounds like they are working on it.
