Embedded Chromecast functionality not working
chromecast
#1
While you CAN use the phone app version or the Chrome extension to cast to the device fine (actually, i can't fullscreen when using the chrome extension), the actual embedded Chromecast button within the software itself only results in "unable to cast. This media is currently unavailable".
Is this a known bug or is there something i'm missing?
#2
Sorry, you're going to need to provide some more information.
 - Plex Media Server version and platform?
 - Which Plex App are you using?
 - What specific version of the Plex App?
 - Does the same library item play correctly in other Apps? (PHT, Plex/Web, Plex iOS App, etc.)
 - Does the "Plex Media Server.log" file show any errors or other info when you try to cast the content?
#3
I found a thread the other day and it looks like a lot of people are having the same issue.
-Plex media server 0.9.8.17.282-c844f09, using win 8.1. That being said i've tried all versions since chromecast was added
-This is plex web - http://plexapp.com/web/ . it works fine when i use the android app version
-android app 3.2.3.67
-Yep. library works 100% fine when using my phone to play things
-Log output
Attached
