FireTV forces a login every day. Any solution/workaround for this?
android-tv
fire-tv
#1
Hi, love the plex.tv ota channels via hdhomerun.connect but my FireTV STick( Latest one from 2017) keeps asking for credentials every time I start the app - the first time in the day. Any way to workaround this? When I go to the PC and link the account - it works fine till the next day. Any pointers? Thanks, Andi
#2
For while it was solved but with the latest Plex Server upgrade - this is back. Fire Stick no longer keeps your login information. each time you power it on - it asks for login info
#3
Maybe try deleting the app and reinstalling it from scratch?
Looks like there’s some other reports of it here:
#4
I’ve seen this issue talked about often, but have never encountered it.
Might it have something to do with the unit being registered at Amazon - legally - or due to some user-invented-geo-blocking-nightmare-work-around?
I run my AFTV signed in - apart from having the world’s worst Plex App installed on it - the box itself seems fine.
