Get library agent info
Hey,
Is there a way to get a list of agents that are enabled for a certain library through the XML API?
It would really help the development/usability of the Sub-Zero Subtitles agent if someone could point me in the right direction here :slight_smile:
Thanks!
I can answer this myself, for example:
http://ip:32400/system/agents/com.plexapp.agents.thetvdb/config/2
