Giant Bomb Channel
#1
Has the Giant Bomb channel been permanently discontinued? I assume so, since all videos stopped working for me and it is no longer available for install in the plugin directory or at https://github.com/plexinc-plugins, but I can't find any one discussing it so perhaps I was the only person using it :)
#2
With no active maintainer it had been sitting broken in the Plugin Directory for ages. After such a long period of time of being broken without anyone interested in fixing it’ll get axed.
#3
It was working fine until the last week or so. Is there an archive of the code anywhere?
#4
@slatkin said:
Has the Giant Bomb channel been permanently discontinued? I assume so, since all videos stopped working for me and it is no longer available for install in the plugin directory or at https://github.com/plexinc-plugins, but I can’t find any one discussing it so perhaps I was the only person using it :slight_smile:
No, you weren’t the only one using it :confused: I’m so bummed that it’s no longer available as now I have to manually download any Giantbomb video I want to watch on TV.
#5
fwiw if anyone still has a copy and wants it to (sort of) work; if you go to settings->web->Internet streaming->quality and chose “maximum” things works as you’d expect at least on the web client; that would lead me to believe transcoding is breaking things, i dont have time currently to figure out what’s broken and given that documentation for plugin dev (whilst available) is a bit cumbersome as long as my current solution works (and I dont find something else I want to add badly enough that some other platform doesn’t already have so I’m basically forced to throw myself against the wall that is lugin doc/dvelopment here I suspect it’;ll stay broken :expressionless: but figured I’d let folks know that there is a work-around as long as setting internet streaming to max doesn’t break ps4/amazon/phone or whatever device you stream to.
