[Guide] Plex Media Server with Intel NUC and Ubuntu 16.04 LTS
server-linux
#1
HARDWARE
  • Intel NUC (BOXNUC7I5BNK, i5-7260U 2,20 GHz, Link)
  • 2 x 8GB DDR4 RAM (CT2K8G4SFD8213, Link)
  • 250GB M.2 PCIe NVMe SSD (Samsung 960 EVO MZ-V6E250BW, Link)
This hardware setup is meant to be an allrounder. Fast enough to transcode multiple movies at the same time, almost completely silent in order to run it in the living room and power efficient in order to run it 24/7. It is able to hardware transcode three H.264 1080p movies at the same time with ~30-35% CPU load. Transcoding a single H.265 4K HDR movie has ~35-40% CPU load.
If you are looking for a single user setup this NUC might be overkill, the NUC i3 with 2 x 4GB RAM should be fine then.
Step 1: Install Ubuntu
  • Update BIOS with latest from Intel's website
  • Install Ubuntu 16.04 LTS 64bit server version
  • Use the following partition scheme (ESP size was suggested by Ubuntu, swap size is much bigger than usual because of RAM transcoding):
#1: 536MB, ESP, bootable
#2: 64GB, swap
#3: 185,5GB, ext4
  • Setup user named plex
Step 2: Install Plex Media Server
  • Add plex repository as source
    • echo deb https://downloads.plex.tv/repo/deb/ public main | sudo tee /etc/apt/sources.list.d/plexmediaserver.list
    • curl https://downloads.plex.tv/plex-keys/PlexSign.key | sudo apt-key add -
  • Install Plex Media Server + dependencies
    • sudo apt-get update && sudo apt-get install avahi-daemon avahi-utils plexmediaserver
    • During installation you will be asked if you want to override the plex repository source with the one from the package. Select yes.
  • Re-enable plex repository source
    • By default the plex repository source from the package is disabled (commented out), enable it in /etc/apt/sources.list.d/plexmediaserver.list
Step 3: Setup NFS and Autofs
  • Install dependencies
    • sudo apt-get install autofs nfs-common
  • Create mount directory and configure Autofs
    • sudo mkdir /data
    • sudo nano /etc/auto.master
    • Append the following line at the end of the file:
      /data      /etc/auto.data
  • Create Autofs configuration file for data directory
    • sudo cp /etc/auto.misc /etc/auto.data
    • Append all your mount points at the end of the file, for example:
      movies    -fstype=nfs4    :/volume1/Movies
      music     -fstype=nfs4    :/volume1/Music
  • Restart Autofs
    • sudo systemctl restart autofs
  • All your mount points are now available at /data/...
  • Autofs will automatically unmount all mount points if there is no access within 5 minutes and remount if you try to access the mount point. You can keep ghost references to the mount points by adding --ghost in auto.master at the end of the appended line
Step 4: Configure Plex Media Server
  • Open http://<ip-of-your-server>:32400/web in your browser and configure your server
Step 5: Setup RAM transcoding
  • Create transcoding directory
    • sudo mkdir /tmp/transcoding
  • Setup the system to mount the RAM disk on every boot
    • sudo nano /etc/fstab
    • Append the following line:
      tmpfs    /tmp    tmpfs    defaults,noatime,nosuid,nodev,noexec,size=64G,mode=1777    0    0
  • Grant writing permissions for the transcoding directory
    • sudo chown -R plex:plex /tmp/transcoding
  • Use /tmp/transcoding in Plex Media Server > Settings > Server > Transcoder > Temporary directory
Additional notes / tips
  • In order to update plex media server it is enough to run the system update: sudo apt-get update && sudo apt-get upgrade
  • If you setup a DDNS service for your server consider to configure the Ubuntu firewall. In that case please check out the Plex reference for which ports you need to allow
#2
@grogster said:
  • #2: 64GB, swap (much bigger than usual because of RAM transcoding)
I ended up going with 8 gigs of ram, (pair of 4G). I may upgrade it later, want to see how it goes with 8. Does that change the size of this swap partition here? should I make it 32 since I am using half the ram you are?
#3
No I would not, as swap is kind of “disk memory”, if the system runs out of memory, it writes parts of the RAM into the swap partition in order to free RAM.
#4
Great guide,. I have tried ubuntu and centos, can’t decide which to keep.
I have the M.2 installed, as well as a few usb 3.0 drives (not ssd) I can use. I’d like to run a seedbox along with Plex (with my Plex video library) What would be the best use of the external drives verses the m.2?
#5
Thanks, very much appreciated!
As both Ubuntu and CentOS are officially supported this is a decision about your preference. As I’m more familiar with Ubuntu I’ve chosen that one.
For storing your video library I would go with the external drives as you’ll need a lot of space and SSD drives are pretty much expensive.
#6
i use my own user to sudo and set everything up. Should the auto log in user script be mine or should it be’plex’? or, does it matter as long as it is the owner of the directory?
#7
Hi
I’m using a similar device as a server (MSI Cubi 2), and I believe these are ideal devices to use for PMS.
I also set up ram transcoding, and I might have a suggestion - I set the ramdisc size to only 2 GB, and everything is working. I know the plex support page says you need to have enough space to hold the entire file, but in my experiance, when the ramdisc is about 90% full, the „old” chunks are deleted. That means you don’t need that much ram (I have only 4 GB), and such a big swap partition.
The biggest file I tried is 6,5 GB 10 Mbps 1080p movie - I have no guarantee that it would work with what you mention. But I’m definately curious :slight_smile:
#8
@checktravis I’m not exactly sure about this, from what I’ve read it should not matter as far as any user is logged in. There were users that reported issues with the server if no user was logged in.
@Cooad good to know! I experienced kind of the same when I played a 60GB 4K movie. Even if this article says “The directory used needs sufficient free space, roughly equal to the size of the source file of the transcode plus 100MB” the transcoding for that movie used almost two times my complete RAM + swap, that’s 100GB more that the source file size. It looked like the old data got cleaned up. Maybe this are optimizations from the linux system.
#9
I’m transitioning off my Nighthawk x10 router. The official firmware offers no shell access so I am constantly running into issues with file permissions, lack of rsync on the server, etc. So, I thought go with a small NUC instead. This setup is working great (thanks again for going through the effort of documenting it).
Question: Running PMS and serving the media files too much for this NUC? I might plug the drives back in to the x10, but transfer rates are so much slower because NTFS seems to be the only format that just works. Netgear says others are supported but good luck getting a stable connection to anything else.
Will start a new thread if this is too off topic.
#10
It shouldn’t be a problem to handle both, there’s no difference in CPU load if you read the data from network storage or USB drives. Just an idea: besides the M.2 connector the NUC has a SATA port on the mainboard. Use this one to get better read/write rates.
#11
Odd they would offer that with no room to use it without leaving it open. I did find these third party cases: http://www.gorite.com/
Thanks for the tip.
#12
i can’t get glances to work. it may be a user/permission issue
gtop
/home/[me]/bin/gtop: line 1: glances: command not found
pip show glances
    Version: 2.11.1
    Summary: A cross-platform curses-based monitoring tool
    Home-page: https://github.com/nicolargo/glances
    Author: Nicolas Hennion
    Author-email: nicolas@nicolargo.com
    License: LGPLv3
    Requires: psutil
tried adding /usr/local/lib/python2.7/dist-packages to path
UPDATE:
following ‘specific user location’ info here https://github.com/nicolargo/glances/blob/master/README.rst
i kept getting
You are using pip version 8.1.1, however version 9.0.1 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
and that suggestion didn’t work, but
pip install --user --upgrade pip
did work, then I was able to
export PYTHONUSERBASE=/home/[me]/
pip install --user glances
export PATH=$PATH:/home/[me]/bin
then gtop works (as does ‘glances’)
#13
Thanks for the guide, really helpful. A couple of questions:
  • did you consider a docker container instead of native install of Plex? If so, any pros in your opinion to this setup vs docker?
  • how do you manage updates to the server? Manually through client prompts, or something else?
Thanks again!
#14
can you explain a little about STEP 10: Setup RAM transcoding?
I am transcoding, df -h shows
tmpfs 64G 51M 64G 1% /tmp
(the only line that matches the size)
sudo ls -la /tmp/transcoding/ -
ls: cannot access '/tmp/transcoding/': No such file or directory
but i see it if i
sudo ls -la /tmp/
#15
@millercentral I bought this machine as dedicated plex server, so I decided to install it natively. I would say pro for docker is that you have it running in its own sandbox, in performance it shouldn’t matter if you got with native or docker. If you check the Dockerfile it uses the same setup with Ubuntu 16.04. I’m not (yet) that experienced with docker, I played a little bit with it by creating a plex webhook for light control and using influxdb + grafana in combination with glances to have a monitoring history. Maybe I’ll decide to switch to docker at some later point. Do you see any pros to the docker setup?
In step 5 I add the plex repository as source, I can now simply do sudo apt-get upgrade and it will update plex server as well.
@checktravis this looks like a permission issue. If you do sudo ls -lsa /tmp/ is owner and group set as the plex user?
You could try to switch to root shell with sudo -i can you access this directory then?
#16
still can’t enter it even with sudo -i
but here is the directory item:
0 drwxr-xr-x 3 plex plex 60 Jan 13 05:20 transcoding
#17
I’ve been following the developments here.
When everything is settled and you have this process boiled down to a procedure / How-To, I will be happy to help with the final formatting and post it up for you in the Linux Tips if you wish.
#18
@checktravis is your question about the df -h command or do you have any issues while transcoding? When I configure a directory as transcoding directory where I setup wrong permissions (root only access for example) and try to play a movie in the browser (this is important, there are no issues in this case when you use the plex media player app) I get an error immediately (“An error occurred tying to play this item. shaka1001 (network)”).
@ChuckPA yes, that would be great! :slight_smile: What would be necessary to have a procedure / How-To?
#19
Another suggestion from me - i believe the autologin is unnecessary. My current machine has no autologin, and the previous one hadn’t either. And the shorter guide, the better :slight_smile:
#20
@Cooad I’ll try that the next couple of days, thanks!
@millercentral I will also test a docker installation of pms, if I runs without issues I re-write that part of the guide
