HD HomeRun Connect connection
server-nvidia-shield
#1
Thinking of changing tuners due to some persistent Live TV/DVR issues with the USB option. My question: If the router is in one room and the antenna is in another (many rooms away), how do I add the Connect to the system?
#2
I have my antenna on my roof outside, and my HDHomeRun Connect is in my basement, next to the router. If you can get a long enough coaxial cable going from your antenna to your Connect, then you are fine. You could also do it with a long ethernet cable....but I prefer the coaxial cable for my setup.
Hope that helps!
