HD icon not showing for 2160p media
aeon-nox
#1
Firstly, thank you, Aeon Nox is an awesome skin! I just recently switched over to it and I am loving the look.
I noticed in one of my video folders that the 1080p files show the HD icon next to them in the list view, however the 2160p videos do not show an HD icon (see attached image). I am not sure if this is a bug or not, but I thought it would be worth mentioning. :slight_smile:
#2
Thanks for the compliments and the feedback.
Can you do the following for me? Go to Plex web and go into a movie section with a 2160p video.
Then select the resolution filter:
After selecting the resolution filter, leave the filter tab open and take a screenshot and post it here like this:
This will provide me with the info I need to get the flags working with 2160p videos.
Thanks.
