Header Compression in MKV files
server-linux-tips
#1
If you encounter any issues with header compression in MKV files, this little script will tell you which files in the current directory are using it.
IFS=$'
for infile in find . -name "*.mkv"
do
uses_compression=$(mkvinfo "$infile" | grep "header removal")
if [ -n "$uses_compression" ]; then
echo $infile
fi
done`
Obviously the script can be expanded and mkvmerge invoked to remux without header compression.
PMS has gotten much better at detecting this but may not catch all cases (AFAIK)/
#2
