Help sideloading
samsung-smart-hub
#1
I am having trouble sideloading the latest version.
I have formatted my usb FAT32
copied the contents of the zip to a root directory named Plex
When i insert the USB I get the prompt to use the flash disk for Videos/Photos?Music
I cancel the message, but there is no new icon in my samsung hub....
Any advice?
Ross
#2
I have UE46ES800UXXU (2012)
#3
It can be found under the Samsung Smarthub apps. On some models it may not have an icon, just a red banner saying user.
Note that there can be several pages inside the SmartHub, so keep pushing right to see if there are more.
#4
its just not there, I must be missing something, I have followed the instructions to the letter…
#5
If it has more than one USB port, try the other one.
Your USB drive should look like this: (my USB Drive is called SAMSUNGBOOT)
#6
Still not working…
That is exactly how my USB filesystem looks…
I’ve even renamed the partition to SAMSUNGBOOT, to match yours, still no joy, any ideas?
#7
tried all 3 usb ports too
#8
None other than, try a different USB drive maybe?
