Hi - I have a telstra (roku device) and have used the developer method to add PLEX as Telstra have locked this down and dont include the PLEX app. I have add PLEX but seems to be an older version - can anyone tell me what is the latest and where i can download this from. Thanks
Hi - I have a telstra (roku device) and have used the developer method to add PLEX as it is not incl
The latest Plex ver. for the Roku is not and never will be available for side loading. Plex considers it proprietary. You can still side load the Plex Classic and RARflix but neither of those have been updated, except for one bug fix, for over a year and never will be again and, eventually, they will stop working as they use the older Roku API.
You can find out about RARflix (A VASTLY superior product to Plex Classic) at:
Thank you for your help i will give RARflix a go… will it find my plex media server?
It should. You can use the pin number RARflix provides during initial setup to discover your server or you can manually enter the server address.
BTW: There are a LOT of settings and it may take some time to get things just like you want.
