nulptr
1
Is it possible to hide the auto-generated Genre (“Pop/Rock”, “Rap”, etc.) that appears under the artist name in the Plexamp Artists view?
Incidentally, where is this information coming from? For some artists, it is absent.
NB: this has nothing to do with searching or tagging; I would just prefer not to see it.
That’s the Genre which is present on the Artist. in Plex.
And no, you cannot disable it in Plexamp.
certuna
3
Are these artist-level genre(s) pulled in by last.fm?
nulptr
4
Thanks, and bummer. Is there a preferred way to request this (seems like it would be easy to implement)?
nulptr
5
Unclear - the picture seems to come from last.fm, but not sure where the Genre is being pulled from. See e.g.
for which Plex has “International” for both Genre and Style.
certuna
6
You can always edit the database directly and remove the genres for all artists in the metadata_items table at once, it’ll take you one minute.
I mean, it won’t mean that they won’t get re-populated on the next “refresh metadata”, but at least you’re done until then.
Standard disclaimer: make backups before you do this.
