Higher h265 bit depth support?
server-nvidia-shield
#1
The bit depth limit of 8 is very limiting, I'm finding I'm having to convert all of my videos.
Any update when PMS is going to support bit depth of 10 or even 12?
#2
The Shield support 10bits h. 265 direct play. With firmware 5.2 and PMS 1.7.4, also support 10 bits transcoding. I don't think the hardware supports 12 bits though.
#3
I have 5.2 firmware and PMS 1.7.4, but still being encoded.
I have attached an XML file of media info.
#4
I think your issue is the same as discussed here:
https://forums.plex.tv/discussion/277598/plex-is-trying-to-transcode-4k-hevc-files-instead-of-direct-play#latest
#5
Resolved in Android Update 6.4.0 https://forums.plex.tv/discussion/comment/1501632/#Comment_1501632
