How do I remove an item from a playlist?
The closest I can find is the word delete, but when I tap on it it says that it’s going to permanently delete the file from my hard drive.
This only works with regular (“dumb”) playlists:
In the playlist view, hold down on the item and swipe it to the left.
Thank you.
What other sorts of playlists are there?
Smart Playlists
