How to change TV Episode display
Server Version#: 1.19.4.2902
Player Version#:Currently do not have access, Updated to current version as of last night.
On a FireCube, how do you change episode display from list to thumbnail? and/or default server to display all the same?
There’s no such option in any of the “Big Screen” apps I know / have tested.
That’s odd, this just started recently. Some seasons of the same show display one way, and other seasons display the other but it is not even consistent across devices. I never saw this list view before, but it seems one by one all my TV series are slowly switching over to it. I REALLY hate it as you can not keep track of what has and has not been watched.
Check the ‘Advanced’ options for the library, or show by 'Edit’ing same.
There is a default display state - and one of them may be what you want.
By Default Plex DVR ‘Collapses’ single season shows - wherein it will only show the episodes, not the Season Poster - then the episodes. That may be what you want.
You can set the display type for your entire library - or for each show.
(you can fiddle with a show - then if you find success - you can apply that to the entire library)
Take a look at that and see what you come up with.
That has nothing to do with the OP’s question.
This is about list view vs. grid view / poster wall
Under advanced there are no display options for the episodes.
I have no option for a default display state.
I do not use Plex DVR at all, and these are programs with multiple episodes in multiple seasons. Some seasons will display one way and other seasons of the same program different way, and differently on different devices.
None of that has anything to do with my problem. In the web admin on the server, click on the 9 small squares in the upper right hand corner. There you can choose grid view, list view or summery view. On my Firecube, some seasons are set to list view and there is no option to change them back to grid view. Changing the view on the server has no effect on what the Firecube (or iPad) sees.
I see
No, it won’t.
That’s an app function - and it might be buggy ATM - as in it’s not there to change.
A Hail Mary at this point is to uninstall/reinstall the app - and hope for the best.
A very recent Android update may have cured it - but we’ll have to wait for it find it’s way to the mosh pit - where FireTV Users live.
The app doesn’t have a list view. Can you take a picture?
I will take one tonight.
That’s my issue, there is no list view available but that is what it is showing. Since there is no menu option to select the view, I can’t change it back.
I figured out what you are seeing. @JuiceWSA was right above with his screenshot. This has to do with the option to hide the season views. The app was never good at handling hiding the seasons. This is what you will see now with that option enabled. This bring up another bug I found. If you change the setting to show seasons and it is still only 1 season, things get wacky.
Well, if we can cure ‘Wacky’ - let’s do it
I’ve already filed an issue with the team to better handle single seasons.
This is what I am seeing. Star Blazers did show the thumbnail view until recently as did the Persuaders. The Pursuaders is now showing this way, without even the titles any longer. I completely uninstalled the app and purged all cache, etc. I also removed the series from Plex server and re-added them again, it made no difference. Really frustrating.
OK, I was screwing around with it, took all series that where having an issue out of the plex server and refreshed. Uninstalled the app again and purged it. Rebooted the server, readded the series. Reinstaleed the app and relinked my device. At first the issue was still there, but then after a few minutes the display went back to what I was used to. No idea what caused it, or what actually fixed it but it is back to “normal” now.
How 'bout a pic of ‘what you’re used to’
I cant get a screenshot right now, but basically just like this, what the server shows.
Yep - the above/above - is quite ignernt.
Glad you got whatever it was - fumigated.
