How to enable myPlex on Plex Classic Roku using your PIN
plex-classic-for-roku
#1
Since we’ve been getting tons of requests in PlexChat about this issue, here are the simple directions for activating myPlex with the PIN when prompted by your Roku box.
Step 1: You need to sign up for a myPlex account. Simply go to this URL and sign up, its completely free:
https://plex.tv
Make sure you verify your account and make sure it is active.
Step 2: On the Roku / Plex channel go to the settings for myPlex. When your Roku prompts you with a PIN number, go to this URL on a computer and enter the PIN:
https://plex.tv/pin
Step 3: Do not forget step #1 !!!
Thats it! You’ll then have access to your myPlex Queue and will be able to connect to your remote and shared servers. You should see your Roku listed in:
https://plex.tv/devices
You must follow these steps. The admins/devs in PlexChat cannot enter PIN numbers for you at all. The entire process is self-service.
Cheers.
#2
Cannot get it to work.
The page you mention asks me to enter a pin in a browser and the roku box asks me also to enter a pin in the TV. What am I supposed to do to link these? Whenever I enter a pin in any of them and submit it I get an error.
#3
The Roku doesn't ask you to enter a pin in the TV, it just shows you a PIN and tells you to enter it in a browser.
1) In a browser, create or sign in to your myPlex account at my.plexapp.com
2) On the Roku, go to Preferences -> Connect myPlex account
3) Follow the directions on the screen, which say to go to my.plexapp.com/pin in a browser and enter the PIN that is shown on the screen.
#4
I got my roku to link perfectly and love it, but......My daughter has plex on her computer and I have it on mine. Each time we try to switch servers we have to re-link the roku box, should that be happening? Is there a way to switch between accounts without having to re-link the roku each time?
Mickee
#5
[quote name='Mickee' timestamp='1334715854' post='256598']
Mickee
[/quote]
I haven't used myplex, but can't she share her library to your myplex account?
#6
I will probably enjoy my plex if I ever get my roku.connected.
#7
On the plex software on my computer I have choice between video channels, channel directory, home movies, queue.
On my Roku all I can see is queue which has videos from youtube using plexit. How do I fix this?
#8
[quote name='robinrobin' timestamp='1340737566' post='274945']
[/quote]
read this
#9
They helped me in the chatroom. I had the wrong IP address entered in the Roku.
#10
With my XD/S Roku simply entering the private channel code: plex and once channel was enabled it found my Plex server shares on my Mac mini right away and was off and running. I am blown away with the video and sound quality playing videos from the Roku vs using VLC on the mini. Developers have done an amazing job integrating Plex with Roku.
#11
Hi guys
quick question, can i use roku internally in my network withou having to sign in to my plex account?
i intend to use it only in my local network, i have my linux plex server setup and running fine now.
I can use plex media centre in my desktop and notebook fine internally, my querie is b4re i go out and spend nearly 190USD on the roku 2xs HD 1080p here in my coutry, i would like to know if it is possible to use it to watch direct from my local network.
any inputs will be appreciated
thkxs
tester10
#12
[quote name='x-techsolucoes' timestamp='1347152918' post='294144']
Hi guys
[/quote]
Yes, absolutely! The Roku client will try to discover any Plex Media Servers on your local network, and if that doesn't work you can always configure one manually.
#13
[quote name='5stringdeath' timestamp='1333039550' post='250041']
Since we've been getting tons of requests in PlexChat about this issue, here are the simple directions for activating myPlex with the PIN when prompted by your Roku box.
https://my.plexapp.com
Step 2: When your Roku prompts you with a PIN number, go to this URL and enter it:
https://my.plexapp.com/pin
Thats it! You'll then have access to your myPlex content and will be able to connect to your remote servers.
Cheers.
[/quote]
I never EVER got a code on my Roku screen. It just straight opened. And it partially works. Not that well though. It also says "You have no servers of your own published to myPlex. " And also MyPlex was unable to connect to server. I have a TWC Ubee router. Hulu won't work. Hardly any channel. I know I would love this if it did! Any suggestions? . I need help!!!
#14
1835
#15
2133
#16
[quote name='pacheco1122' timestamp='1349542666' post='300962']
1835
[/quote]
[quote name='pacheco1122' timestamp='1349542838' post='300963']
2133
[/quote]
Dont enter PINS in this thread. Do it on your myPlex page as indicated in the first post
[quote]
[/quote]
#17
When I go to your link to enter my Roku pin, I get warnings about security and trojans. What do I do?
#18
How exactly does this help me? I enabled it, and see no changes. Is this to be able to use plex on my roku when I travel?
#19
[quote name='bluedevil229' timestamp='1357053492' post='332634']
[/quote]
Yes.. This also gives you to access to your "myplex" que
#20
0653
