Hello, I have some shows who have multiple seasons but only one season appears in Plex, how can I add the second season to the seasons menu ? The files are like this : TV Shows/TV Show Name S1/01.mp4
And also I have some shows with different languages (Japanese and French), only one language shows at the same time. I would like to change languages the same way I change subtitles.
The files are like this : TV Shows/TV Show Name/French/01.mp4
Not the best naming. This will likely give you all kinds of problems.
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
Should be more like this.
TV Shows/TV Show Name/Season 01/TV Show Name - s01e01.mp4
TV Shows/TV Show Name/Season 01/TV Show Name - s01e02.mp4
TV Shows/TV Show Name/Season 01/TV Show Name - s01e03.mp4
TV Shows/TV Show Name/Season 01/TV Show Name - s01e04.mp4
TV Shows/TV Show Name/Season 02/TV Show Name - s02e01.mp4
TV Shows/TV Show Name/Season 02/TV Show Name - s02e02.mp4
TV Shows/TV Show Name/Season 02/TV Show Name - s02e03.mp4
TV Shows/TV Show Name/Season 02/TV Show Name - s02e04.mp4
Example from the above article.
/TV Shows
/Grey's Anatomy
/Season 01
Grey's Anatomy - s01e01.avi
Grey's Anatomy - s01e02 - The First Cut is the Deepest.avi
Grey's Anatomy - s01e03.mp4
/Season 02
Grey's Anatomy - s02e01.avi
Grey's Anatomy - s02e02.mkv
Grey's Anatomy - s02e03.m4v
Again, not good. Plex doesn’t know what French is.
You have some options on how to get plex to handle these correctly.
The easiest would be to name the series(using the names you provided)
For your french
TV Shows/TV Show Name [French]/Season 01/s01e01.mp4
And your japanese
TV Shows/TV Show Name [Japanese]/Season 01/s01e01.mp4
Plex will find both series and combined(merge) them together. You will need to split them apart(unmerge) them from plex.
https://support.plex.tv/articles/201018248-merge-or-split-items/
Thanks a lot ! I will change this as soon as possible
