How to mount media from your NAS shares on Linux using NFS
server-linux-tips
#1
Mounting NFS network shares for Plex use on Linux .
The basic checklist
A. Prepare the NAS:
B. Create a 'mount point' directory structure on your Linux machine which will be where all your media shares are grafted and made available for Plex use.
C. Create an entry in /etc/fstab for each share you wish to mount.
D. Mount and debug as needed
A. Prepare the NAS.
This is unique to each NAS. In general, you only need grant read permission. Should you desire Read/Write for yourself, we will allow for it
On Linux, Plex uses username plex. The username plex is the most desirable username to use for your NAS as well.
  1. Add username plex to the NAS. If it requires a password, assign it one and you can use it later if/when needed.
  2. Edit the share permissions for your NAS to either export 2a. "Read-only" to your LAN (all hosts) for all usernames -or- 2b. "Read-write" for your username, and Read-only for plex
B. Create the Mount Point directory structure
It usually makes the most sense to create a structure which mirrors your NAS's shares
An example structure might be:
/nas
/nas/movies
/nas/movies2
/nas/children
/nas/tv
/nas/cartoons
/nas/photos
/nas/music
To create this, we simply supply the Linux commands to create the structure and supply the basic permissions to those directories:
sudo sh
mkdir /nas  /nas/movies /nas/movies2 /nas/children /nas/tv /nas/cartoons /nas/photos /nas/music
chmod -R 755 /nas
exit
C. Create the entries to mount the NAS shares at their target locations.
Each nas vendor has a different pathname conventions. Please follow the documentation for your NAS.
In this example, Synology's and QNAP's conventions will be shown.
The photos library will be mounted Read-only to prevent accidental deletion by anyone.
The example systems are a twin volume Synology DiskStation and a single volume QNAP system
You will notice the two nas units are seamlessly blended together here. In the end, Plex will complete the blending into a single library if so desired.
/etc/fstab has the following entries added to it. These will require testing and possible adjustment for your NAS and configuration. NFS is shown here first.
if you have defined the hosts syno and qnap in /etc/hosts, you may use their names here otherwise use their IP addresses.
You may always use hostname or IP address interchangeably as long as there is a definitive resolution.
syno:/volume1/movies     /nas/movies           nfs    auto,defaults,nofail 0 0
qnap:/share/movies2      /nas/movies2          nfs    auto,defaults,nofail 0 0
syno:/volume1/children   /nas/children         nfs    auto,defaults,nofail 0 0
syno:/volume2/tv         /nas/tv               nfs    auto,defaults,nofail 0 0
qnap:/share/cartoons     /nas/cartoons         nfs    auto,defaults,nofail 0 0
# QNAP is .21
192.168.0.21:/share/Photos       /nas/photos           nfs    auto,defaults,nofail,ro 0 0
# Syno is .23
192.168.0.23:/volume2/music      /nas/music            nfs    auto,defaults,nofail 0 0
Save the file and now we begin testing.
D. Begin verifying and testing the new mount points
sudo sh
mount -avt nfs      # each will attempt to mount and give dialog as it does.   Look for "successfully mounted"
# follow up by seeing what actually is mounted
df
# check to see if you have visibility into each share
cd /nas
ls *     # This will list all the top level output from each share and will be voluminous so be prepared
If you have made any errors, you may work at the individual mount level
sudo sh
mount /nas/movies
ls /nas/movies
# Um,  i don't like that.   ... change mount in /etc/fstab
umount /nas/movies
# after editing, try it again
mount /nas/movies
Repeat the above until you're happy with all
There is one final step which will often help avoid permission issues on Linux systems (should the NAS be very security conscious)
This sets the permissions of the directories after they have been mounted too, effectively tweaking the NAS permissions a bit looser (read-only)
sudo chmod 755 /nas/*
All your network (NAS) media is now available to PMS starting with the /nas folder at the top.
#2
