Server Version#: Version 1.27.0.5897
Player Version#: Vizio, web and roku players
Windows 10 PC
I really enjoy the watchlist feature, in the past day or so I added two movies but instead of showing the movie poster there is a blank box with the text “error”. There are no active controls on the blank boxes so I cannot delete them or mark them as watched.
Is there some place in the filesystem that I can remove them.
Thanks in advance
Do you remember which movies they were? The watchlist is not stored locally.
Thanks!
Two documentaries:
After Porn Ends
After Porn Ends 2
If you go to the details pages for those movies then they should have the remove from watchlist button. If you do a search for them you should be able to get to the detail pages. I’ll let folks know there is an issue with removing them when in watchlist.
BigWheel, thx that worked, I was able to remove them. Thx for the quick response!!
Is there a way to remove the “error” item if you don’t remember what they were? Because I have an “error” sitting in my watchlist, but it was something I don’t remember and there’s been a lot of added items since.
