I made a mistake and the PlexOnlineToken from Preferences.xml on my local PMS is possibly compromised. I don’t have a reason to think it’s been used or seen by anyone (yet) but I want to reset it asap.
The way I understand it - this is the master token that associates PMS with app.plex.tv account. I know where to remove my home server from authentications (https://app.plex.tv/desktop/#!/settings/devices/pms) but I’m trying to figure out how to minimize or avoid data loss, specifically: my home profiles, watch history, libraries, settings and similar. I know I can disassociate the home server from plex.tv and re-claim using the claim token but I don’t know if that’s the best way to prevent or minimize data loss.
Using the Plex web app, you go to
Settings - [server name] - General
and use the “Remove” button.
This will invalidate the server token.
Then stop and restart the server.
Thank you @OttoKerner . It worked perfectly. The script couldn’t find my Preferences for some reason (I’m running the official image in Kubernetes) but at least it had a fallback and I could provide the path. All came back as if it never happened!
Edit:
Actually there was one more part to this. Just removing the PMS server was not enough, it came back with the same PlexOnlineToken . I had to also go to Settings → Authorized Devices and remove it from there as well. Then I was able to receive a fresh Token.
