How to toggle library display settings
aeon-nox
#1
I somehow switched from the wall of posters to the vertical list view and I have no idea how I did it. How do you toggle through the various navigation/library screen options?
#2
if i understand you correctly, you probably you changed the main menu setting from horizontal to vertical
Skin Settings, Home Window, Main menu orientation, change it back to Horizontal
#3
I am an idiot.
