How to use Plex on Xbox 360
xbox-360
#1
Hello everyone, I am new to this forum. I would like to know how to use Plex Tv with Xbox 360. I totally have no idea how to get through. First timer.
#2
Find and load the Plex App on your Xbox from the app store.
Set up the app with your Plex Login Credentials.
That's about it.
#3
im going to go very basic as you are saying yo have no idea... so i will take that NO IDEA literal..
  1. you need Plex installed SOMEWHERE
  2. verify you can connect to it via a pc - web browser
  3. xbox 360 app install and login
  4. should be able to play from there
#4
Hey, thanks for the reply, i will try this out over the weekend when i am off work and will update you how it goes.
#5
Got it done over the weekend. So far it is working great. Don't mind if i bug for any other issue.
#6
nope never do! thats what were here for!!!! B)
#7
ok I won't do that LOL ;)
