Just installed the latest plex app for my smart LG tv and when I try to sign into my server it just displays the server cannot be found page and I cannot access the four options on the bottom with my TV remote, to sign in or to try again. It’s like it’s frozen. I can exit the app no problem but every time I try and open the app it displays the same page. I cannot even get to the plex pin code to authenticate. I’ve tried un-installing the app and reinstalling it but it still goes to the same page.
I was wondering if this was a cache issue with the tv but I can’t see a way of clearing any app data or cache through the options. Any suggestions guys…
Well it can’t hurt unless you have had your TV calibrated professionally. I do recommend taking a note of your settings prior. In the server settings /Network make sure you have server connections as preferred.
Also having problems with the latest Plex server update on an LG TV with webOS. In my case, the Plex app on the TV finds the home page, but any attempt to play any media results in the ‘spinning yellow circle of doom’ - on a few occasions, the server responds but then the content stops after a few seconds. I find that streaming the same content via the Plex app on iOS works fine, as does casting the content to the same TV using a Chromecast - so it seems that the latest server update has resulted in some incompatibility with the Plex app on the LG. I realise that the Plex app for LG (webOS) has not been updated for some time, which is a bit disappointing, but it has worked for me up until today. In addition, the XPlay app for LG is behaving in the same way, so I do think that this is a server update problem. Any thoughts on what might have gone awry with the update to Version 1.18.7.2415?
Found the directory alright - last update in there was version 1.9.7.4460-a39b25852 dated 16 November 2017. If I go back to there from version 1.18.7.2415-9930aef45 I think I might break the world Is there anywhere you know of that keeps more recent PMS versions?
Thanks for the help - backtracked to PMS version 1.18.6.2348 with help from SE56 and got back to a working version. Looks like that’s the end of the road for PMS server updates for me unless whatever issue was introduced in 1.18.7.2415 gets resolved.
Well I guess nobody has the same issue as me with my LG app not allowing me to sign in or change server etc… damn was hoping somebody may have experienced this…
