Incorrect matching problem
server-windows
#1
Hello all.
My PMS is always incorrectly matching the show Hindsight (2015). When adding a new show to my monitored folder, PMS always thinks the show is Hindsight (2011). The files (and containing folder) are named as: Hindsight.2015.S01E01, etc., yet PMS always thinks this is the 2011 version and so PMS downloads the wrong metadata for the program. Then I have to go and fix it.
Big problem? No. Annoying? Yes.
So is there any fix this?
#2
try adding the Parenths to the 2015
 Hindsight (2015).S01E01
#3
^^ That... and you only have to do (2015) for the main show folder. Hindsight SxxExx.xxx will be fine after that - I think.
When in doubt - go to the source: http://thetvdb.com/?tab=series&id=288464
