Infinite reboot loop on LibreElec/Raspberry Pi
plex-for-kodi
#1
This discussion was created from comments split from: (ONLY FOR SERIOUS TESTERS) Bleeding Edge Testing Releases.
#2
WARNING official kodi repo 1.4 script version causes infinite loop reboot in Raspberry.
Please check
#3
Please check
I’ll need a Kodi log, since I’m not seeing that here.
#4
Please check
Double checked. Fresh libreelec working without addon. Once installed then infinite loop rebooting.
https://pastebin.com/eGt00m6h
script 1.3 ran fine
#5
Split this to avoid cluttering the other thread.
I’ve attached a special build that reverts the one change that I think could possibly be triggering this. Please try it out and let me know if it fixes the issue.
Thanks,
Rick
#6
This build is working now.
It would be great to fix it as soon as possible in Kodi repo.
Thanks,
Alfie
#7
Thanks,
Alfie
Yeah, I’ll update it, though this appears to be a bug with Kodi on the Raspberry Pi or possibly LibreElec specifically. The crash was happening before the add-on ran any code, and it’s not happening on any other platform. The add-on has a small script that runs on startup that checks to see if the setting to auto-start the add-on is true. The only change I made wasn’t even in code, just the addon.xml setting that determines when that script is run. I changed it back to starting on Kodi start rather than on login (on login is useful if you use multiple profiles).
#8
Pushed to the Kodi official repo, pending mirror updates.
#9
Thanks Alfie and ruuk,
this fixed my issue also.
Thankfully I only use two other add-ons, so was able to diagnose the cause before any tufts of hair and curses were flung around the living room.
Cheers,
AzzA
