Download Kodi
https://kodi.tv/download/
v17 "Release" Installation
- In Kodi, Browse to
Add-ons.
- Select
Download at the bottom.
- Select
Video Add-ons.
- Select
Plex.
- Select
Install.
- After it's finished installing, Hit
Esc and select Plex from Add-ons.
V16 "Older Release" Installation
Videos > Add-ons.
- Select
Get More...
- Select
Plex.
- Select
Install.
Esc and run Plex.
v18 "Development" Installation
v18 is not supported currently.
Updates
The repo will take up to 24-48 hours for all the mirrors to see the new update. Sometimes 'Check for New Updates' on the repo itself will refresh it, other times you must wait. Be patient if you don't see the latest version, it will be auto-updated once you do.
