Interesting use for Plex and kodi
plex-for-kodi
#1
I can't believe the timing sometimes everything just comes together. I recently a new truck. Well this Honda runs android 4.2 so last week I rooted to install some third party apps including kodi. I was looking into installing ds audio to get my music on the unit. But with this plug in and a WD wireless pro I can run a Plex server and Plex on the head unit. A almost perfect car setup. Just need to figure out the install.
#2
Let us know how it goes! I'm not quite sure how this add-on UI works on a touchscreen interface, you might want to try it on an Android tablet first before install. :)
#3
I am concerned about the size also. Might just use kodi touch screen skin.
#4
Retouched/Estouchy are great but won't work with the Plex Add-on, FWIW.
#5
Will they be supported in the future?
Also I've noticed that the default theme is a little bit off on my Lenovo tab 2 a10-30 (1280x800) in terms of what I touch and what I get :)
Since this is designed as a TV interface, the priority level to support the touchscreen skins is much lower...
#7
I've been using Plex for Android on my head unit for years :)
#8
That's a completely different app with different priorities to a Kodi skin.
