iOS 17 beta top bar displaying in middle of screen
Server Version#:1.32.6.7468
Player Version#:8.25
When using the iOS app I’ve noticed an annoying bug. I open the app and everything is fine. Then I play anything. When you exit the movie or show and it goes back to wherever you were in the app the top menu bar is floating in the middle of the screen. It only fixes itself if you force close the app. On ios17 RC. But it’s been happening for a few iOS versions now (17 betas).
PlexDebugInfo-ktwingstrom-8.25-6861 (2023-09-15 23.10.56 -0600).zip (1.9 MB)
Same issue. iPhone 14 pro, latest server, iOS version, iOS app. Really fricken annoying… they have gotta know about it by now…
Not Plex as such IMO but moreso iOS17 as I’ve seen it with a few other apps.
Have not had the issue pre iOS17.
17.1 should be out very soon.
