iPad 12.9 lastest model unable to stream
ios
#1
Hi Don't know if anyone else is experiencing issues however i seem to be unable to stream movies etc on my new iPad i have a number of devices that don't have any issues inc mac and iPhone and android tablets / chrome cast with very little issues with bandwidth etc.
Is this a bug people are aware of?
Any advice would be greatly appreciated as the screen on the iPad looks great with Netflix.
Cheers
#2
Do you have the iOS 11 beta installed?
#3
Nope I don't have the beta installed
#4
I have the new 12.9 wifi 4G 512GB and no problem here.
#5
Similar problem here, funny enough I can only stream SD TV-shows, HD-movies I only get sound, but I have iOS beta II installed on my new 12.9 iPad, on my iPad 10.5 with same beta no problem!
#6
I have a similar issue on my iPad Pro 10.5” running iOS 11 public beta 2.
The movies play with sound, but no picture..
Works fine on my iPad Pro 9.7” running iOS 10.x
#7
I have something similar with my iPad Pro 10.5". I'm running iOS 10.3.2, Plex app 4.15, and Plex Server 1.7.6.4058.
When I try to stream to the iPad Pro it takes an age to start then usually stops with a message about the server connection being too slow. If I use an iPhone 6s or iPad Mini with all the same versions, and in exactly the same spot they work fine.
