iphone and Chromecast problem
chromecast
#1
Hi, I have a small problem when I try to change the quality over my phone connected to my Chromecast. This start after the last update. Like you can see on the screenshot, I can’t change the quality. But if I use my Android phone, everything is ok. I can changed the quality like I want. Any idea why or if i’m alone with this problem.
Thx all.!
#2
Here is the scrrenshot :slight_smile:
#3
I am having the exact same problem.
#4
Good happy to be not alone :) If I found something, I will let you know :)
#5
Same problem. I've yet to see any solutions or even acknowledgement from plex staff of the issue.
#6
Also seeing this issue
#7
Another one having the same issue. I can change the quality settings just fine from my PC.
